The computability path ordering. F. Blanqui, J.-P. Jouannaud and A. Rubio. LMCS 11(4), 45 pages, 2015.
This paper aims at carrying out termination proofs for simply typed higher-order calculi automatically by using ordering comparisons. To this end, we introduce the computability path ordering (CPO), a recursive relation on terms obtained by lifting a precedence on function symbols. A first version, core CPO, is essentially obtained from the higher-order recursive path ordering (HORPO) by eliminating type checks from some recursive calls and by incorporating the treatment of bound variables as in the so-called computability closure. The well-foundedness proof shows that core CPO captures the essence of computability arguments a la Tait and Girard, therefore explaining its name. We further show that no more type check can be eliminated from its recursive calls without loosing well-foundedness, but one for which we found no counter-example yet. Two extensions of core CPO are then introduced which allow one to consider: the first, higher-order inductive types; the second, a precedence in which some function symbols are smaller than application and abstraction.
Statcounter W3C Validator Last updated on 22 April 2023. Come back to main page.
